How to add Landing property to a leader
Hi all,
Is there any way to add “landing” property to a Leader created within a code with scripting?
I am using a code;
pts=
pts.extend([pick_pt, point2])
leader = rs.AddLeader(pts, text=layerName)
rs.ObjectLayer(leader, layer)
rs.ObjectColor(leader, (170,5,5))
rs.ObjectPrintWidth(leader, 0.2)
Thanks in advance…
PS
The full code is on attachment
AddLeaderTag.py (1.7 KB)
Hi @yigit, not with plain RhinoScriptSyntax, but you can use some RhinoCommon in Python to do it inside your script eg:
    leader_id = rs.AddLeader(pts, text=layerName)
    # change landing
    leader_obj = rs.coercerhinoobject(leader_id, True, True)
    leader_obj.Geometry.LeaderHasLanding = True
    leader_obj.Geometry.LeaderLandingLength = 1.0
    leader_obj.CommitChanges()
    scriptcontext.doc.Views.Redraw()
@dale, please have a look at below attached script. I’ve tried to create the leader using RhinoCommon and found that i cannot set LeaderHasLanding and LeaderLandingLength before adding the leader object to the document. There seems to be something i do not get while setting both properties or they are forced to be read from the current dimstyle. (Note, the script is supposed to work on named objects picked in a layout/detail view).
AddLeaderTag_CG.py (2.8 KB)
thanks,
c.
Thank you !! :grin:
