I have a series of VBScript files that I publish in a few different plug-in files.
Each of these scripts has a related HMTL file (and other image files) that provide an interface for that script.
The problem I have is that when using the RhinoScriptCompiler and “.rhi” file naming functionality, I can only put the additional files in a similar location/branch to the plugin file (which is directly related to the plugin it’s installed in).
Now this is fine if this plug-in is the only plug-in the script is ever used in (as I can reference the additional files’s path via the rhino.plugininfo() function, but since I use this script in multiple plug-ins, this wont work.
I really need to be able to install the additional files into a common folder, rather than a plug-in specific one.
Any ideas?
Thanks,
Shane,
