How to add a 2D symbol visible on plan views when creating a new REVIT door or windows family from Grasshopper Rhino inside components ?
There are not GH components to create 2D linework at the moment. You can use the python component however to create the necessary linework programmatically.
Tanks for your answer !
You can use the FamilyElement.ByCurve component to add symbolic curves to the family.
Here it is the definition Window.gh (38.4 KB) .
Great that is exactlly What I was trying to do !
Wondering if anything has changed since this solution? I’m having difficulty with a casework family I’m creating with all lines made with the “Component Family Curve” coming in as model lines regardless of symbolic being toggled to true?
yer its a weird one… I tried starting the family as a generic family and then changed it to casework in GH after the initial generic family creation… and the linework all came in as symbolic… so seems to be a bug in there somewhere.
