Hi, I am building my own cluster with several C# components and a “ZombieSolver” from Kangaroo2. The primary purpose is to delete the repeated mesh face from the cluster input.
I know the C# component probably causes the heavy computing part. Here is my code. I wonder how I can make it as faster as possible. Are there any ways to activate the GPU in the C# code?
(one of the recent tries takes 1.7HR to finish the algorithm) (the cluster)
(here is the c# part)
using System;
using System.Collections;
using System.Collections.Generic;
using Rhino;
using Rhino.Geometry;
using Grasshopper;
using Grasshopper.Kernel;
using Grasshopper.Kernel.Data;
using Grasshopper.Kernel.Types;
/// <summary>
/// This class will be instantiated on demand by the Script component.
/// </summary>
public class Script_Instance : GH_ScriptInstance
#region Utility functions
/// <summary>Print a String to the [Out] Parameter of the Script component.</summary>
/// <param name="text">String to print.</param>
private void Print(string text) { /* Implementation hidden. */ }
/// <summary>Print a formatted String to the [Out] Parameter of the Script component.</summary>
/// <param name="format">String format.</param>
/// <param name="args">Formatting parameters.</param>
private void Print(string format, params object[] args) { /* Implementation hidden. */ }
/// <summary>Print useful information about an object instance to the [Out] Parameter of the Script component. </summary>
/// <param name="obj">Object instance to parse.</param>
private void Reflect(object obj) { /* Implementation hidden. */ }
/// <summary>Print the signatures of all the overloads of a specific method to the [Out] Parameter of the Script component. </summary>
private void Reflect(object obj, string method_name) { /* Implementation hidden. */ }
#endregion
#region Members
/// <summary>Gets the current Rhino document.</summary>
private readonly RhinoDoc RhinoDocument;
/// <summary>Gets the Grasshopper document that owns this script.</summary>
private readonly GH_Document GrasshopperDocument;
/// <summary>Gets the Grasshopper script component that owns this script.</summary>
private readonly IGH_Component Component;
/// <summary>
/// Gets the current iteration count. The first call to RunScript() is associated with Iteration==0.
/// Any subsequent call within the same solution will increment the Iteration count.
/// </summary>
private readonly int Iteration;
#endregion
/// <summary>
/// This procedure contains the user code. Input parameters are provided as regular arguments,
/// Output parameters as ref arguments. You don't have to assign output parameters,
/// they will have a default value.
/// </summary>
private void RunScript(Mesh MeshToReduce, ref object Deleted_Faces, ref object ReducedMesh)
Mesh m = new Mesh();//temperory mesh for adjustment in the algorithm
m = MeshToReduce;
int faceCount = m.Faces.Count;
Print("The original Mesh Face Count = " + faceCount.ToString());
//int[] faceID = new int[faceCount];
List<int> faceID = new List<int>();
Point3d[] faceCenter = new Point3d[faceCount];
//fill-in faceID and faceCenter
for(int i = 0 ; i < faceCount ; i++)
faceID.Add(i);
//List<int> Facelist = m.Faces;
List<int> DeleteFaceID = new List<int>();
Point3d CurrentFaceCenterPt = m.Faces.GetFaceCenter(i);
for(int j = 0 ; j < faceCount ; j++)
bool status = false;
for(int k = 0 ; k < DeleteFaceID.Count ; k++){
if (i == DeleteFaceID[k]) status = true;
if( status ) break;
if( i == j ) continue;
if(CurrentFaceCenterPt.DistanceTo(m.Faces.GetFaceCenter(j)) < 0.01 || CurrentFaceCenterPt.DistanceTo(m.Faces.GetFaceCenter(j)) == 0)
DeleteFaceID.Add(j);//int
DeleteFaceID.Add(i);//int
Deleted_Faces = DeleteFaceID;
m.Faces.DeleteFaces(DeleteFaceID);//removed Faces that is duplicated
Print("The reduced Mesh Faces Count = " + m.Faces.Count);
ReducedMesh = m; //ouput
// <Custom additional code>
// </Custom additional code>
