I see these can be set via Rhino.DocObjects.ConstructionPlane properties, but I don’t see how to access the current settings and/or change them via scriptcontext.doc… must be missing something dumb here.
There is scriptcontext.doc.NamedConstructionPlanes, but that is only for custom CPlanes as far as I can tell.
You can get the current construction Plane
cPlane = sc.doc.Views.ActiveView.ActiveViewport.GetConstructionPlane()
then modify using those methods https://developer.rhino3d.com/api/RhinoCommon/html/T_Rhino_DocObjects_ConstructionPlane.htm :
cPlane.GridSpacing = 40.0
And because GetConstructionPlane()
seems to make a copy you need to set afterwards:
for view in sc.doc.Views:
viewPort = view.ActiveViewport
viewPort.SetConstructionPlane(cPlane)
sc.doc.Views.Redraw()
OK, that’s really interesting… Even after all this time with Rhino, I never realized you can actually have a different grid spacing in each view - which is why I was looking for a global setting… Well, you learn something every day… Thanks!
