Hi there,
i need 8 cylinders 45 degrees apart around this front plate. These should later be slots for screws. I haven’t worked with this feature before and somehow it never works the way I need it … any tips?
Frontpalte.3dm (170.8 KB)
Hi there,
But how can I adjust the distance? So it has to be all around but with a distance of 45 degrees
Are you using Array or ArrayPolar? To copy objects around a circle use ArrayPolar. ArrayPolar uses the number of objects and the angle to array the objects around, not distance.
https://docs.mcneel.com/rhino/7/help/en-us/index.htm#commands/arraypolar.htm
Enter the number of objects desired. 8 is the number for objects arranged at 45 degrees intervals around a circle.
Enter the angle to arrange the objects around. 360 is the number for around a complete circle.
