Can the ImportFillsAs option be set from Python when importing a PDF?
If this is not currently supported, could that option be exposed in the Import command?
I tried using RhinoDoc.Import, but there is no documentation about to use ArchivableDictionary options.
Thank you, this worked:
options = FilePdfReadOptions()
options.PreserveModelScale = True
options.PDFScale = 1.0
options.PdfUnits = FilePdfReadOptions.PDF_UNITS.inches
options.RhinoScale = 1.0
options.LoadText = True
options.ImportFillsAsHatches = True
doc.Import(page_pdf_path, options.ToDictionary())
