Hi, I have one question regarding to the RhinoDoc method.
I would like to use RhinoDoc.Import to import some CAD files in Rhino Document, and here’s the code inside the C# scripting component.
private void RunScript(string filePath, bool read, bool export, ref object A)
if(read)
RhinoDocument.Import(filePath);
if(export)
RhinoDocument.Export(@"D:\tmp.pdf");
Like the photo shows, after I press the first Read Toggle. Rhino Document called the Import method, and stop the grasshopper once.
I have to manually check the Set DWG import options in the Rhino Document to move on, but I basically always just press Enter, using the default options.
I would like to ask if there’s a way that I can automation this process with some scripts in C# component. Making the Rhino Document knows that I accept all default options( User don’t need to press
Entermanually), and start import.dwgfiles in RhinoDoc.
Here’s the sample files:
architectural_example-imperial.dwg (145.2 KB)
RhinoDocImportQuestion.gh (8.3 KB)
Thanks. All the best.
