How do I resize a ring with Grasshoper?
I have made several rings and I would like to be able to resize them easily to have them in different sizes. Can you explain me the commands I can apply to resize my rings in a quick and easy way because I don’t know how to use Grasshoper.
Thanks in advance,
Have a nice day.
Here’s a simple demo.
Ring_re.gh (14.7 KB)
Ring_reV2.gh (16.3 KB)
Thank you very much, can you tell me if I just need to copy this and put it on each file of each ring or is it more complicated?
As I mentioned, it’s just a demo and you can probably only refer to the logic of this code.
In this case, I used a circle as a base geometry for the ring to vary the radius.
Ok thanks, do you know if there are other techniques to resize a ring?
It defends how you created your ring… Maybe you could use Scale, but you won’t be able to have precise radius control.
Ok, thank you so much
