How do I remove edges and join them?
I would appreciate it if you could let me know the problem.
Please correct it.
def create_fillet_rectangle():
# Define the points of the rectangle
pointA = rs.AddPoint(30, 0, 0)
pointB = rs.AddPoint(60, 73, 0)
pointC = rs.AddPoint(-60, 73, 0)
pointD = rs.AddPoint(-30, 0, 0)
# Add the polyline
pt = [pointA, pointB, pointC, pointD]
profile1 = rs.AddPolyline(pt)
# Mirror the polyline
profile2 = rs.MirrorObject(profile1, (0, 0, 0), (1, 0, 0), True)
# Join the curves
joincrv1 = rs.JoinCurves([profile1, profile2])
if not joincrv1:
print("Failed to join curves.")
return
# Set the fillet radius
fillet_radius = 20
# Explode the joined curve into segments
segments = rs.ExplodeCurves(joincrv1[0])
if not segments or len(segments) < 2:
print("Failed to explode joined curve.")
return
# Apply fillets between each pair of segments
fillets = []
for i in range(len(segments)):
seg1 = segments[i]
seg2 = segments[(i + 1) % len(segments)]
fillet = rs.AddFilletCurve(seg1, seg2, fillet_radius)
if fillet:
fillets.append(fillet)
if fillets:
# Delete the original segments
rs.DeleteObjects(segments)
rs.DeleteObject(joincrv1)
# Join the filleted curves
fillet_ids = [seg1] + fillets
for i in range(len(fillets) - 1):
fillet_ids.append(fillets[i].Split(0.5)[1])
joined_fillet = rs.JoinCurves(fillet_ids)
if joined_fillet:
print("Fillets applied and curves joined successfully.")
else:
print("Failed to join filleted curves.")
else:
print("Failed to create fillets.")
if __name__ == "__main__":
