Like UnrollSrf command does to curves, breps and Dots?
I need unrolled points to inherit the attr’s of their inputs and Dots to keep their colors.
It looks like it should, but I get this error:
Message: 'type' object has no attribute '__index__'
Traceback:
line 42, in SampleUnroller
EDIT: Had to restart Rhino.
if curves:
rev = len(curves) - 1
for j in range(len(curves)):
attr = sc.doc.CreateDefaultAttributes()
print unroll.FollowingGeometryIndex(curves[j])
if unroll.FollowingGeometryIndex(curves[j]) >= 0:
attr = panelcrvs[rev - j].Attributes
attr.RemoveFromAllGroups()
sc.doc.Objects.Add(curves[j], attr)
It seems that Unroller enumerates unrolled curves in reverse order, which is easy to fix.
But dots are enumerated in some random order and I have no clue how to fix it.
Hi @Asterisk,
TextDot objects seems to unroll in selected order (see attached 3dm file). I used the SampleUnroller.py
script I referenced above.
SampleUnroller.3dm (85.2 KB)
What am I missing?
– Dale
The problem is that mine aren’t manually selected. I click the “panel” which has everything needed to be unrolled grouped and script sifts thru group members building lists of curves, and dots. Curves it handles in sensible order, but dots are random. I’m missing something that UnrollSrf command does that our script doesn’t in regards of ordering dots (input order =! output order).
Rename zip to mkv:
2021-03-16 20-21-25.zip (6.0 MB)
Hi @Asterisk,
TextDot
inherits from GeometryBase
. Thus you can attached all sort of user data/text on one of these that will help you track tehse in the manner you need.
– Dale
Got it! So, if I want all attribute User Text values passed onto unrolled objects, I just need to duplicate them in Geometry User Text?
