I already have a point cloud, opened in Rhino 7. I can select it, and all the points are selected, but I can’t figure out how to create a curve from that. I don’t want to make new points, or select all the points individually. I can’t find a command to do that.
The Section or Contour commands will slice through a point cloud and make choppy curves.
You’ll probably need to clean up the curves before that will be useful for creating surfaces.
Thanks, I was able to get that to work.
