Hi
I have a problem with tools. Normally when I used the «standard» set of tools, I had the Pallette with all the standard tools right below. Now this link seems to somehow be broken and I didn’t find out how to fix it. As soon as I choose a different toolset (for example the ones for volumes) this is gonna change the tools below. When I go back to standard, the volume tools stay below and I can’t get the standard tools back… how do I correct that?! I didn’t even change something intentionally - I never had any problems like that with former rhino versions (since Rhino 4…) only with version 8.
I start with the standard-tools (top row). Below on the left side, I have the standard tools available. As soon as I go to for example the volume tools, this changes to volume tools.
No one knew? I found it out. A hassle… but now it works. You can do a right click in to the Toolbar and choose properties. There you have the possibility to choose sidebars to link. Then you can choose which ones you would like to link. First though you have to find out how their names are in order to choose the right one…
