Rhino 8 Toolbars not showing
Hello. its the first time im interacting in this forum, but I really need some help.
I use rhino for a long time, and now im using rhino 8. it was everything running normally in the begining, but since from 2 days ago every time I open rhino the toolbars are all gone and I can only see the model space… not even the commands are working. the problem is that when I go to the toolbars setting and try to enable the standard toolbars, rhino shutdown immediately. does anyone know how to fix this situation?
I appreciate any help.
im using Rhino 8 for Mac.
Hi Vinicios -
Please run the Rhino SystemInfo command and copy-paste the result here.
is that other way to show you that information, because the command dialog box is not showing either. its not assuming any command I type
Hi Vinicios -
If there are any menu items at the top of the screen, pick Window -> Window Layouts -> Default Window Layout.
