Can’t figure out how to eliminate the face circled in the image. What should I look at to figure out what’s making this geometry “unselectable” ?
thanks!
face-delete.3dm (232.2 KB)
thanks!
extract de surface, delete it, and cap the object
Hi - thanks - yes, tried that, and it worked; however, I’m curious how to figure out what was breaking the object.
Without knowing how you created it, it’s difficult to say
Created by:
Pretty sure that was it. That said, it could happen with a model that someone else built, too, so you might now know how it was made.
Hi! Don’t forget: you can always select brep components (like this superfluous surface) with CTRL-SHIFT, then simply delete them. No need to extract them first.
