How do I extrude a surface along a curve and keep the face normal to the curve?
I would like to do something like this:
Instead the face always stays the same and the effect does not work.
Is there a way to do this in Rhino?
you can use sweep1 but you need the curves for it. you can also quickly use DupBorder to create the outlines of the text. after that you use sweep1 which you unfortunately have to do on each curve separately.
Thanks. I tried “natural” setting and got it to work.
