I basically want to repeat this module throughout to create a semi permeable facade. help me out please
window dtail.3dm (266.3 KB)
Do you have a drawing how this should look? Most likely you want to work this out in Grasshopper. The method depends on what you have in mind.
I’d prefer spaces on the spaces on the outside since they do have to touch to be structurally reasonable. In fact, if you could a slight overhang on the outside is fine and is even preferred.
You can do that with an Array.
Give this a whirl. The parameters are adjustable, but the plane orientations may need to be slightly modified given your input curves/surfaces.
