How can I reduce the zones on SubD object?
I have a Sub model like this. But the parts I circled has too much surfaces (I dont know if its the right term) but I want it to have less surfaces like nearby objects. How can I make it?
Hi -
You can sub-object select an edge by holding Ctrl and Shift when clicking on an edge. When you double-click, you can select an entire loop. With such loop selected, hit the delete key to delete it.
Alternately, run QuadRemesh on it and make a new SubD with less faces.
I also filed this similar request a while back for future reference…
https://mcneel.myjetbrains.com/youtrack/issue/RH-55563
another option for such cases - DupEdge and SubdLoft
2
