Hi guys!
I’m quite new to the Grasshopper field but I’m eager to learn.
That’s why I have already tried for 4 months now to solve this problem on my own and with different books and tutorials, but I arrived at the end of my nerves.
Now here is my issue:
I own a ceramic 3D-printer and want to try this “loops pattern” in a simple form (with extruded curves in the respective layer height, so that the slicer also understands it and that I don’t need to export .gcode directly from GH).
The problem I face is, that if I want to move points away from the original surface, to generate the loops path ( a zig-zag curve), the points are oriented normally to the wavy surface and don’t spread evenly and parallel to the ground plane.
I hope you know what I mean.
I put my definition down here and also a screenshot of how the object looks like in my Rhino window and how the loops should approx. look like in the end.
Please help – you are my last chance!
Thank you in advance.
Loops Try.gh (18.3 KB)
