How can I modify this node using Rhino/Grasshopper?
Node Help.3dm (797.9 KB)
I need some help modifying this node in either Grasshopper or Rhino. I have made this spaceframe node using multipipe in Grasshopper. However, I am looking to modify the lower sections (as seen in the curves image) so that I can 3D print it potentially without support. The black lines indicate how I would like the new geometry to drape. I want the final geometry to look like one organic form and not as though I have just joined two disparate pieces of geometry.
If anyone could please help I would be hugely appreciative.
Thank you!
This is a potential ShrinkWrap workflow (Latest Rhino 8 WIP)
Here i populated the curves and bottom surfaces with points to create a quick low res structure. Creating a rough solid or surfaces for the structure then wrapping would yield better results.
something like this (created surfaces below, then mesh Boolean differenced
That’s awesome! Thank you!
How did you do the second one?
I’ve just downloaded Rhino 8 WIP, I’ll have a play around with it now…
