How can I make each unit move within a constant height?
Hello. I hope the height difference betwee each adjacent unit(cubic) of this figure is only up to the height(170mm) that a person can climb. What should I do?
how to make this move within a constant slope.gh (38.1 KB)
This is a good question.
how to make this move within a constant slope v0 Wire Reorganised.gh (19.3 KB)
I have not changed the original script a bit, only reorganized the wires. Use this gh file to save some time.
Your gradient is very shallow, meaning that it will be difficult to create such a dramatic shape with only 170mm rises. The simplest way seems to be a kangaroo simulation - we can calculate what the largest possible distance between points can be with Pythagoras’s theorem, but as we start to limit the Z, your shape quickly becomes unrecognisable:
I’m attaching a simple Kangaroo set-up for you to play with:
how to make this move within a constant slope.gh (38.2 KB)
Thank you. Is the height between each point 170?
