How can I get hint in Script Editor?
How can I get this kind(red) of friendly hint of method in the R8 Script Editor.
And please tell me how I can do python script in VS Code.
Below is the whole code I have written following the tutorial.
Hi @Quan_Li, its only available when you type using the old editor (_EditPythonScript):
The R8 editor doesn’t show it when typing, only when you select an item in the help panel:
@eirannejad, could you add this to the new editor in the terminal when typing ?
_
c.
RH-78115 Support hint/signature provider for python
Please also add that to GhPython (python 3) component in Grasshopper. I am in a hard process of learning GhPython, that feature is very helpful.
Please also add Autocompleting parentheses function to Python3 Script Editor. It will make coding in the Editor easier. Thank you!
