Hi, does anybody know how i can make a surface between these 2 edges, i mean, how i can fill this whit a surface
usually you would only take one curve and use slab. since you have both upper and lower surface already you can simply loft the edges if they are continuous, sweep 2 will also work if you create one perpendicular curve to both edges.
Sweep two rails?
