so as the picture show, i want to trans the right one to the left one. thanks.
kinds of you, thanks, i will have try
@HS_Kim
I saw your post on grasshopper3d on “splitting prep fails”. I love the boolean split component, thanks!
Now I have a situation where it won’t work. Would you mind taking a look?
I can’t get the second boolean split to work.
First split.
Second split.
booleansplit.gh (207.8 KB)
The reason why it fails is because you cannot split a continuous loop with any of the cutters into 2 parts. So you will first need to cut this object into two objects by other means, then perform that second boolean split.
Thank you!
