Im a Mac user using rhino 8 and im unable to delete the scripts which was not the case in windows when I was using on rhino 7 back then, is it that rhino 8 has an issue or im just unaware about how to delete it
what kind of scripts can’t you delete?
Unable to delete any scripts which I make
example I select the rectangle in grasshopper im unable to delete that
I’m on windows, but I guess you should have the equivalent of this GH preferences window also in MAC
under Interface there’s a long list of shortcuts you should be able to customize in order to bind the Delete function to any keyboard key
Thanks matter will revert back once I check it out
Got it thank you!!!
