How can I create this Brep shape only in Grasshopper?
Hi everyone,
I’ve been working on a definition in Grasshopper (see the attached images), where I currently use a few components to generate this curved Brep form. However, I’d like to recreate the same shape purely in Grasshopper without manually modeling or referencing geometry from Rhino.
Right now, I’m not entirely sure how to construct the same surface directly from parameters or logic within Grasshopper. Could someone please point me in the right direction or suggest which components or workflow I should look into? Any advice or examples would be greatly appreciated!
Thanks in advance for your help.
Here is a simple approach for you reference. If you’re unsure how to use any components, please check the website below for related instructions. Hope this helps.
ExtrudeBrep.gh (12.0 KB)
You’re a lifesaver, genuinely, thank you so much.
Hi again,
I was wondering if there’s a way to grab the centroid of the object and incorporate it into the edge surface, as the arches seem too high. I tried adjusting the height and then attempted to use Area to capture the center points of the top and bottom surfaces, but this caused the other components to break.
Please give it a try with Network Surface, and fyi.
NetworkSurface.gh (15.1 KB)
