How can I coding runtime message in Rhino 8 's Grasshopper SDK?
I have try to convert program from Grasshopper in Rhino 7 with IronPython to Grasshopper in Rhino 8 with both IronPython and Python3 but not successful.
This error are intend after compiled it to a component
It would be great if anyone can suggest me on how to fixed it.
Here are what I have try
There are 5 different source:
  • Code A, SDK and Class(component) with ghenv.Component in class
from ghpythonlib.componentbase import executingcomponent as component
import Grasshopper
import System
import Rhino
class MyComponent(component):
    def RunScript(self, x, y):
        a = 1
        blWarn = ghenv.Component.RuntimeMessageLevel.Warning
        ghenv.Component.AddRuntimeMessage(blWarn, "Balloon Message")
        ghenv.Component.Message = "Component Message"
        return a
  • Code B, SDK and Class(component) but use self instead of ghenv.Compoent in class
import Grasshopper
import System
import Rhino
        a = 1
        blWarn = self.RuntimeMessageLevel.Warning
        self.AddRuntimeMessage(blWarn, "Balloon Message")
        self.Message = "Component Message"
        return a
  • Code C, SDK and Class(GH_ScriptInstance) with ghenv.Compoent in class
import System
import Rhino
import Grasshopper
class MyComponent(Grasshopper.Kernel.GH_ScriptInstance):
        a = 1
        return a
  • Code D, SDK and Class(GH_ScriptInstance) but use self instead of ghenv.Compoent in class
import System
import Rhino
import Grasshopper
        a = 1
        return a
  • Code E, Procedure Mode with ghenv.Compoent
a = 1
On Rhino 7
  • Complied Component with Code A will give an error
    RH7_ghenv
  • Complied Component with Code B are working properly.
On Rhino 8
Build Target is Rhino 8
  • Complied Component with Code A or Code C, will give an error
    RH8_A
  • Code B or Code D, Can’t Compile as an error
  • Complied Component with Code E are working properly. !!! this in procedure mode
Here are test overview and attached code
rh8_message.zip (80.5 KB)
Thank you very much
Hello @NongKode
I made a GH definition here that shows how these scripts can work or not work. I left notes close to each one for your information. The C# component has a bug that I will get that fixed, but this should clear up the confusion:
test_sdkMode.ghx (468.7 KB)
Let me know if you still have questions and I’d be happy to clarify more
Hi @eirannejad
Thank you very much for your precious time and answer :star_struck:
The problem are occur on Complied SDK Type
I have select 3 component from your example
  • CODE A : Cleaner (SDK)
  • CODE C (SDK)
  • CODE E : Cleaner
and complied as upper image, Do I miss some thing while complie it ?
then the result of them are error on SDK component but not on Script
all related files are attatched
test_sdkMode.zip (284.7 KB)
If you not mind would you please also suggest on this topic :pray:
Best Regards
Oh I see so this is with published components. Okay let me look into it. I’ll update here.
RH-81638 Published python components are missing ghenv
Ok. I made a fix for this and will be available in next 8.7 RC build
Thanks for reporting!
RH-81638 is fixed in Rhino 8 Service Release 7 Release Candidate
RH-81638 is fixed in Rhino 8 Service Release 7.
