Solid_r5.3dm (11.4 MB)
Your file is large and my connection is slow.
Does Scale1D or ScaleNU help?
No, it streches it all the way, i just want to make it wider
Can you upload a .3dm file with just the piece of geometry you want to change? You can use Export to create a file with selected objects.
Scale1D only changes an object in one direction. ScaleNU allows different scaling or no scaling in the x, y and z directions.
Object for scale.3dm (4.4 MB)
Thanks for the answer but i can’t realy work out what u told me, can u send the file you worked on?
Thanks in advance
Hello - see the attached file - Solid_r5_PG.3dm (3.9 MB)
Hi Pascal, Would explode ,then offest srf to 1.2 cms work?
That’s the approach I would use. Explode and delete everything except the outside surfaces, then OffsetSrf with Solid=Yes.
Yep, that works as well - probably quicker.
