Is there any way to add up items in a branch? Each of the item has same length in all branches.
The idea is to sum up those multiple items in the same branch and get one item in each branch.
HI
use the âInsert itemâ for insert item to list.
use the âTree branchâ for take specific branch.
use the âSplit treeâ for take all of even or odd branch.
Thanks for your ideas! Unfortunately, both of these components couldnât solve the current problem, since the output from the âmonthlyâ has both text and value.
I have tried to internalize the output, but every time when I saved in a new document, it doesnât show what it should be. Iâm guessing it might be related to the output is from LB plugin.
