Hotkey for the command “turn off all bindings”?
hotkey for the command “turn off all bindings”?
I tried to install it in the settings but couldn’t.
the hotkey is called alt, but is only possible during commands, so for instance when you activate the move command then press alt
You want to toggle Enable/Disable object snaps?
The command macro is _DisableOsnap _Toggle. It is a toggle, each time you run it, it will either enable or disable the Osnaps.
