Hello there,
I’m trying to run hops for a local .gh definition. Connecting to the local server has been spotty (sometimes working and sometimes not). Not ideal
Perhaps unrelated to this, the specific issue I have is below. Every time I do manage to connect hops, I get an error: Swallowing exception in PriorityLoad: Parameter count mismatch.
System.Reflection.TargetParameterCountException: Parameter count mismatch.
The .gh file is attached - uses lunchbox components. I think I’ve set up all the hops components correctly.
Would someone please advise why I may be getting this error upon startup? or if its related to failing to connect sometimes?
Foam_city.gh (19.1 KB)
Thank you
