Hops - setting tree access to "true" won't output a flattened item
Is there a way to output a flat data tree if tree access is set to true? The only workaround that I have found is to flatten the result - outside of - the Hops component.
Hops internals
Hops in a document
gh file:
HOPS TEST TREE ACCESS.gh (5.0 KB)
This might be a bug. I’ll have to take a closer look.
