Hi @AndyPayne ever since the 0.16.20 update, my Hops components havent been working in Rhino Inside Revit. Even after setting the path it remains empty like this
All these Hops components work in regular Rhino and used to work in Rhino Inside Revit before 0.16.20 as well.
Every time I start grasshopper in Rhino Inside Revit it throws this HopsLog at me. Could you have a look at this and let me know what the issue is?
Priority: HopsLog
Method not found: ‘Serilog.LoggerConfiguration Serilog.FileLoggerConfigurationExtensions.File(Serilog.Configuration.LoggerSinkConfiguration, Serilog.Formatting.ITextFormatter, System.String, Serilog.Events.LogEventLevel, System.Nullable1<Int64>, Serilog.Core.LoggingLevelSwitch, Boolean, Boolean, System.Nullable
1<System.TimeSpan>, Serilog.RollingInterval, Boolean, System.Nullable1<Int32>, System.Text.Encoding, Serilog.Sinks.File.FileLifecycleHooks, System.Nullable
1<System.TimeSpan>)’.
MissingMethodException
In addition, I get these errors if i attempt to open a gh file which contains Hops components
Message log start (chronological):
Plugin version: 1.0.0008
Object ‘Hops’ {c69bb52c-88ba-4640-b69f-188d111029e8} failed to deserialize itself: Object reference not set to an instance of an object.
Object list read
