Hops Default Value Issue
New to Hops but see great potential.
I am trying to set the default numeric value for an input so that the item can be optional (by setting the ‘At Least’ to 0). When I attach a panel directly to the Hops input, it works fine. However, I want the value to vary based on the model units. When I try to give the value from another component (such as a multiplication component to convert the unit), the default does not work. Is the default value only limited to panels?
