I am trying to make and application which will hook in to the running instance of Rhino and make some operations. But if there are tow or three instance how will i switch between the instances?
I am using this VB 6.0 code
Set RhinoApp = CreateObject(“Rhino4.Interface”) < – this hooks in to the firstly created instance of Rhino. but i want to switch between the Rhino’s running.
hi
i had the same problem and it’s technical not possible to access all instances with CreateObject.
I solved the problem with a own interface in my own rhino plugin, which exposes the functionality i needed. A lot more work, but it’s working perfectly.
hi
i’m afraid it is not possible to create a plugin in VB6. But there is also a C# interface available which i would recommend to you.
In detail i made a webservice within the plugin which can be accessed from every program language and also over network.
