I’m talking about this option here:
Is this possible to do using Python?
Since you are scripting, an easy way is to just script the HidePt command.
– Dale
Hi Dale, does that mean this is not possible using RhinoCommon?
I do not want to script commands unless I have no other choice. (like for example using squish command. Or the Hydrostatics command.
A bit about the background I have developed a bundle of scripts for grips and eventually I want to turn this into a plugin.
A grip is just like any other object. So you can hide it in same manner.
– Dale
Is this something new? Before grips didn’t have guid, they were not objects like points.
The following code is hiding all points not just the grip (control point) I’ve selected.
import Rhino
import scriptcontext as sc
pt = rs.GetObjectGrip()
print pt[0]
#Rhino.DocObjects.Tables.ObjectTable.Hide(pt[0],True)
sc.doc.Objects.Hide(pt[0],True)
Fun with grips:
import Rhino
def test_hide_pt():
go = Rhino.Input.Custom.GetObject();
go.SetCommandPrompt("Select control points to hide")
go.GeometryFilter = Rhino.DocObjects.ObjectType.Grip
go.SubObjectSelect = False
go.GetMultiple(1, 0)
if (go.CommandResult() == Rhino.Commands.Result.Success):
for objref in go.Objects():
sc.doc.Objects.Hide(objref, False)
sc.doc.Views.Redraw()
def test_show_pt():
filter = Rhino.DocObjects.ObjectEnumeratorSettings()
filter.NormalObjects = False
filter.LockedObjects = False
filter.HiddenObjects = True
filter.DeletedObjects = False
filter.ActiveObjects = True
filter.ReferenceObjects = True
filter.IncludeGrips = True
rh_objects = sc.doc.Objects.GetObjectList(filter)
for rh_obj in rh_objects:
if not rh_obj.IsHidden:
continue
if rh_obj.ObjectType != Rhino.DocObjects.ObjectType.Grip:
continue;
sc.doc.Objects.Show(rh_obj.Id, False)
– Dale
Thanks @dale,
This is exactly what I needed.
