Cant not turn off object grips in v5 (c#)
Hi;
I run this core in v5 sr14, after the program stop, the surface’s grips still turn on.How cant I turn off the surface’s grips?
            Rhino.DocObjects.ObjRef objRef;
            Rhino.Commands.Result rc = Rhino.Input.RhinoGet.GetOneObject("Select surface for control point editing", false, Rhino.DocObjects.ObjectType.Surface, out objRef);
            if (rc != Rhino.Commands.Result.Success)
                return rc;
            Rhino.DocObjects.RhinoObject obj = objRef.Object();
            if (null == obj)
                return Rhino.Commands.Result.Failure;
            Rhino.Geometry.Surface srf = objRef.Surface();
            if (null == srf)
            obj.GripsOn = true;
            doc.Views.Redraw();
            Rhino.DocObjects.GripObject[] grips = obj.GetGrips();
            for (int i = 0; i < grips.Length; i++)
                Rhino.DocObjects.GripObject grip = grips[i];
                double u, v;
                if (srf.ClosestPoint(grip.CurrentLocation, out u, out v))
                    Rhino.Geometry.Vector3d dir = srf.NormalAt(u, v);
                    dir.Unitize();
                    dir *= 0.5;
                    grip.Move(dir);
            doc.Objects.GripUpdate(obj, true);
            obj.GripsOn = false;//Cant not turn off object grips
            doc.Views.Redraw();
            return Rhino.Commands.Result.Success;
Hi @pythonuser,
This should do the trick…
  var rc = RhinoGet.GetOneObject(
    false,
    ObjectType.Surface,
    out var obj_ref
    return rc;
  var obj = obj_ref.Object();
  if (null == obj)
    return Result.Failure;
  Rhino.Geometry.Surface srf = obj_ref.Surface();
  if (null == srf)
  obj.GripsOn = true;
  doc.Views.Redraw();
  var grips = obj.GetGrips();
  foreach (var grip in grips)
    if (srf.ClosestPoint(grip.CurrentLocation, out var u, out var v))
      var dir = srf.NormalAt(u, v);
      dir.Unitize();
      dir *= 0.5;
      grip.Move(dir);
  var obj_id = obj.Id;
  // Object has changed, so 'obj' is no longer valid
  // So, reacquire the object...
  obj = doc.Objects.FindId(obj_id);
  if (null != obj)
  doc.Views.Redraw();
  return Result.Success;
– Dale
Hi @dale:
Think you, it run good.
