Hide parts of object(s) that fall outside the boundary of another object?
Is there an option to temporarily hide parts of objects that fall outside the border of another specified object?
For example, when playing around with the position of the pattern in the image below, I’d like for all parts of the pattern outside of the rectangle to be hidden as I move the pattern around to make it easier to visualize what the pattern will look like once trimmed… without having to do and undo trims repeatedly. Sort of a trim live-preview.
If you’re familiar with CorelDraw’s “PowerClip” feature, where you can place any number of other objects inside the boundaries of a closed curve and only see the parts of those objects that are within the boundaries of the PowerClip, I’m looking for something like that but watered down I suppose.
Thanks
Hi Peter - you’ll have to make a mask - trim a rectangular hole out of a plane, or make a solid hatch, to hide the bits you don’t want to see.
