R8 - Request - SilhouetteHighlighting - API Access?
I realize I may be jumping the gun here but I wanted to put out a request to expose the API access/methods for the new Silhouette Highlight that is available in Document Properties.
Rhino.Options.ChooseOneObject.HighlightColor = (Color)
Rhino.Options.General.SilhoutteHighlighting = True
This is exposed in the Rhino → Document Properties → Rhino Options → Advanced settings.
I am looking for the API access to this method to be able to use this highlight method to dynamically highlight specific Rhino Objects from within a script.
An example would be “on hovering a UI button, it gives a silhouette highlight around the objects corresponding to said button”
OR
Another example "running a command like “show_warnings” in a custom script that then highlights problemed portions of geometry with a silhouette highlight in a warning color like “red” or “warning yellow”
In summary, I would really like to use the Silhouette Highlight as a callable method from scripting and be able to set the color and thickness of said highlight so that we can have this to augment the selection and/or display experience when dealing with objects.
I know there are Display Conduits that could get a similar effect in some cases but I’m specifically looking for the “silhouette highlight” not just DrawWires or DrawingCurves
Thanks for your consideration and response!
@michaelvollrath - you can do this today.
#! python 2
import Rhino
KEY = "SilhouetteHighlighting"
# Gets the value of Rhino.Options.General.SilhouetteHighlighting
def GetSilhouetteHighlighting():
    settings = Rhino.PlugIns.PlugIn.GetPluginSettings(Rhino.RhinoApp.CurrentRhinoId, False)
    if settings:
        child = settings.GetChild("Options").GetChild("General")
        if child:
            return child.GetBool(KEY, False)
# Sets the value of Rhino.Options.General.SilhouetteHighlighting
def SetSilhouetteHighlighting(value):
    if settings:
        child = settings.AddChild("Options").AddChild("General")
        if child:
            child.SetBool(KEY, value)
# Tests the above
value = GetSilhouetteHighlighting()
print("{}: {}".format(KEY, value))
SetSilhouetteHighlighting(not value)
Use the same pattern for Rhino.Options.ChooseOneObject.HighlightColor.
– Dale
Thank you @dale this is great,
I’ll use this for now, much appreciated
Hi @dale ,
Silly question… How do I set enums and ints?
SetBool is used to set the boolean value.
Do I use “SetEnum” and “SetInt” ? or is there a different naming convention for trying to set the options like below that takes an int value:
child.SetInt("SilhouetteHighlightInnerFactor", 0)  # Set the SilhouetteHighlightInnerFactor
Thanks for the help!
EDIT:
Nevermind, found it in the API docs here, sharing for anyone else in the future!
https://developer.rhino3d.com/api/rhinocommon/rhino.persistentsettings
https://developer.rhino3d.com/api/rhinocommon/rhino.persistentsettings/setinteger
This is the corrected call:
child.SetInteger("SilhouetteHighlightInnerFactor", 0)  # Set the SilhouetteHighlightInnerFactor
