Hide Current Layer Please
please let us hide the current layer already, it is so painful having to breakdance your way there instead of one simple click onto a bulp.
there are quite a few topics where this was requested, i did not dig up all the requests, but these are certainly the more recent ones
edit:
i found an open tracker that is partially related RH-70584 what these request and mine are instead are to turn of the current layer.
On the list now as RH-85102 Layer: Turn Off Current Layer
Would you expect a warning to pop up when a user creates an object while the layer is off?
thank you @wim
i personally would just have it turn on automatically since turning on is what i would have to do then anyway. i think a user should just be aware what layer they are drawing on
+1 for allowing the current layer to be off. A smaller nuisance, but a frequent one.
Summary:
  1. It should be possible to make the current layer hidden.
  2. Setting the current layer to some hidden layer will not make this layer visible.
  3. Trying to create something on a hidden layer will just make the layer visible.
Personally, I would avoid all types of pop-ups as they tend to prevent extensions or scripts from working. Sometimes Rhino simply writes in the prompt what could go wrong or has gone wrong. I think this is the best way to inform and allow some freedom. At least a global flag in the options to warn via popups or command prompt. When you get used to a software you need reminders not show-stoppers.
Regards
+1
Great summary, @Eugen !
@dale i saw this is on your list, is there any chance we could have this in v9? it is a small change (i guess and hope) but it would be such a game changer in fiddling with layers for quick overviews. since there have been numerous requests for this it might be a thankful implementation.
