Hidden Feature? ObjectColorSource = from material
I have just noticed that the object color source can be set via RhinoScript to ByMaterial (#2). It is actually quite nice possibility (it derives from the diffuse color of object’s material). Is there a way in Rhino to set this without script? I don’t see it in Properties panel or -Properties command line options…
It would be nice if from Material worked with Layer material if Object’s material source is set to ByLayer…
