Laoky
(Loïc Gillioz)
September 22, 2023, 3:32pm
1
Hey there,
Sorry to reactivate this topic years later.
I would like to create Materials for objects from their Display Color, and not from their Layer Color.
The idea is to get the same colors, on both the Shaded View and in the Rendered View. Very basic stuff.
Is there some command to do that ?
Or should I do some scripting ?
@dale you might have an idea maybe.
Thanks a lot in advance and best regards,
Loïc
Laoky
(Loïc Gillioz)
September 22, 2023, 3:43pm
2
Just found this as well, which works fine. I post it for others
Thanks for the help, it’s solved.
There you go
import Rhino
import scriptcontext
import System
def CreateMaterialFromDisplayColor():
rhino_objects = scriptcontext.doc.Objects
for obj in rhino_objects:
try:
display_color = obj.Attributes.DrawColor(scriptcontext.doc)
material_index = scriptcontext.doc.Materials.Add()
material = scriptcontext.doc.Materials[material_index]
material.DiffuseColor = System.Drawing.Color.FromArgb(display_color.A, display_color.R, display_color.G, display_color.B)
material.CommitChanges()
obj.Attributes.MaterialIndex = material_index
obj.Attributes.MaterialSource = Rhino.DocObjects.ObjectMaterialSource.MaterialFromObject
obj.CommitChanges()
except Exception as e:
print("An error occurred while processing object {obj.Id}: {e}")
Hope this helps
-Farouk
Amir2
(Amir)
January 8, 2024, 12:42am
4
Thanks, thank you, it helped me a lot
