I want to flow the cells in a hexagonal grid along a certain curve direction but I don’t how… I’ve tried certain methods but I’m pretty new to grasshopper so I was unabe to achieve the desired result (2nd Image)
please post the script along with it
There is a multitude of solutions. I thought you could use Map to Surface to transform your 2D pattern onto a lofted surface and then project it to XY again. Bake starting surface and curves of the lofted surface to fine tune the result.
20_05_31_hex_along_curve.gh (9.6 KB)
