Hex panel extrusion line attractor
Hi
I’m trying to add two attractors, 1. a point attractor for the hex panel sizes (it works fine) 2. line attractor to control the extrusion height. (failed)
not sure where I need to connect the Curve Closest Point to get it work.
I’m also trying to put the hex pattern on a surface… please direct me which components I should use.
hex.3dm (22.1 KB) hex_v2.gh (18.2 KB)
Right! Thank you so much.
The last question was how to put it on a rhino surface… could you also help with this one?
is it better to use ‘hex cells or hex structure’ (lunchbox)? or can I use the current hex grid component?
yeap thats it, thank you so much.
Hi There
I got another question on the same def. How do I fill in the edges? I want all edges to have triangles to finish the form nicely.
hex_v3.gh (18.5 KB)
I’ve used clean tree tool before but not sure if thats the right component.
Have a try Hexagon Cells fr lunchbox plugin instead ofHexGrid.
hex_v3_re.gh (17.3 KB)
Thank HS_Kim, I’ve failed with Hexagon Cells initially, now I see what I’ve missed.
