Help with grasshopper nodes
Hello, i’m having issues with the use of some node in grasshopper, they’re not reacting as they have to.
When i put them on the canvas, they got stuck on the left top corner, they cant move and frezze, and dont react, if anny one can help me, thanks.
ERROR_INSIDE_02
ERROR_INSIDE_03
The Pollination/Ladybug discourse forum can give you plugin specific support.
thanks for the reply @Japhy, but is not only the the pollination/ladybug nodes, some nodes from Kangaroo, LunchBox or other pluggins act some times the same, other times, i got a red screen,
the main issue is this: Grasshopper Archive messages
failed to deserialize itself: Unable to cast object of type ‘Grasshopper.Kernel.Types.GH_Integer’ to type ‘Grasshopper.Kernel.Types.GH_Number’.
on pollination told me that this kind of error / issue is something that you should ask for help in the McNeel forum. It looks like a glitch in Grasshopper. There is nothing out of the ordinary that we do with these components. They are just user objects created from GHPython components.
At this point, i dont know if its the Rhinoceros Instalation, the hardware, the machine, python…
That’s why i ask for help.
Thanks in advance.
Please type SystemInfo in the Rhino command line and post your results.
Is this happening in all gh files or just this one?
@Japhy this happend with other gh files, but i have to open one by one to see wishone have the error, some of them works fine, other ones don’t work.
here’s the Rhino info, Thanks in advance.
Regards
Guillermo.
Info:
Rhino 7 SR30 2023-6-12 (Rhino 7, 7.30.23163.13001, Git hash:master @ f695e494df78377a81b2b95edb99c6067e324b33)
License type: Educational, build 2023-06-12
License details: Cloud Zoo
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 64Gb)
Computer platform: LAPTOP - Plugged in [99% battery remaining]
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 3-2-2023 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 4070 Laptop GPU (NVidia) Memory: 8GB, Driver date: 2-20-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 528.66
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 2-20-2023
Driver Version: 31.0.15.2866
Z-Buffer depth: 24 bits
Total Video Memory: 8188 MB
C:\Users\guill\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\D5Conv (e0d5e210-02f6-4ee9-a2b0-1675e225d958)\0.10.1.0001\Rhino 7\D5Conv.rhp “D5Converter for Rhino”
C:\Users\guill\AppData\Local\Programs\Enscape\Bin64\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.23156.747
C:\Users\guill\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\ggRhinoIFC\23.7.4.0\ggRhinoIFC.rhp “ggRhinoIFC” 23.7.4.0
C:\Users\guill\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\Fologram for Rhino (468a328b-20d9-494b-b9e1-cbe9f827d3a2)\2020.3.5.0\7\Fologram.IO.Rhino3d.Win7.rhp “Fologram for Rhino” 2020.3.5.0
C:\ProgramData\McNeel\Rhinoceros\packages\7.0\LadybugTools\1.38.57\Ladybug.RH.Loader.rhp “Ladybug.RH.Loader” 1.38.57.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.30.23163.13001
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Users\guill\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PanelingTools\2021.3.2.446\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.30.23163.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.30.23163.13001
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.30.23163.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.30.23163.13001
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.30.23163.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.30.23163.13001
Lets open Rhino in safe mode and launch Grasshopper (accept to load the .rhps). Then open your script, this will eliminate any interference from any Rhino plugins that do not ship with Rhino.
@Japhy, it didnt change anny, even i found more nodes with this kind of error now, and others give me a new message error.
Screenshot 2023-07-15 193225
Screenshot 2023-07-15 193311
Screenshot 2023-07-15 193342
Have you done a repair install? Go to Add or Remove Programs and Modify>Repair your Rhino Install. If that doesn’t clear up your issues make sure your plugins are being properly installed (unblocked)
@Japhy I did all that, i start from removing all software like python, and then installing the versions that i use to have on the other laptop, repair Rhino, uninstall, download again from food4rhino the apps, unblock them, install them, and the problem persist, i also check all the drivers for the machine, update for windows, and all i can think about or see in forums.
The main issue it’s that i have a presentation next saturday and i cant make any simulations or progress on my research, thats why i’m so persistant (sorry in advance).
Thank for all the help.
I’ll wait for futter instructions.
best regards.
I think we need to get you to a point where SystemInfo has no 3rd party plugins are installed, as well as no Grasshopper plugins, then add one by one until we figure out which plugin is causing this.
