i’ve been getting this error on the most recent wip whenever i try to use grasshopper
still pinpointing exactly when/why it happens but ive noticed it mostly when adding or moving an object, even just ‘curve’
Does this happen in a blank file or in a particular definition? This looks similar to the ol’ massive text box issue (at some point too much text in a panel would through a graphics error)
blank file, i added a point or something trivial and then deleted it. i did take some sort of action to trigger this both times it happened, but it def wasn’t related to too much text in the panel.
i would start a new project then take 1 or 2 actions and was met w that popup and this red screen
i did update .net thru vscode for something a few weeks ago, this is the first time ive used grasshopper since. might it be related to that?
This looks like the graphics error i mentioned.
Please run SystemInfo in Rhino and post the results. Thanks!
Rhino 9 SR0 2026-5-12 (Rhino WIP, 9.0.26132.12306, Git hash:master @ e4ca4a25a2667146cdb0b9e48607c637ec745bdb)
License type: Educational, build 2026-05-12
License details: Cloud Zoo
Expires on: 2026-06-26
Apple macOS Version 15.7.5 (Build 24G624) (Physical RAM: 64GB)
Mac Model Identifier: MacBookPro18,4
Language: en-US (MacOS default)
.NET 10.0.2
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Apple M1 Max
Color LCD (1800 x 1169 @ 120.00Hz)
GPU Vendor: Apple
USB devices
None
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswift_Builtin_float.dylib
/usr/lib/swift/libswift_errno.dylib
/usr/lib/swift/libswift_math.dylib
/usr/lib/swift/libswift_signal.dylib
/usr/lib/swift/libswift_stdio.dylib
/usr/lib/swift/libswift_time.dylib
/usr/lib/swift/libswiftsys_time.dylib
/usr/lib/swift/libswiftunistd.dylib
/usr/lib/swift/libswiftDistributed.dylib
/usr/lib/swift/libswiftObservation.dylib
/usr/lib/swift/libswiftSynchronization.dylib
/usr/lib/swift/libswiftNaturalLanguage.dylib
/usr/lib/swift/libswiftMLCompute.dylib
/usr/lib/swift/libswiftDataDetection.dylib
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftSwiftOnoneSupport.dylib
/usr/lib/usd/libusd_ms.dylib
/usr/lib/swift/libswiftSpatial.dylib
/usr/lib/swift/libswiftPassKit.dylib
/usr/lib/swift/libswiftAppleArchive.dylib
/usr/lib/swift/libswiftVideoToolbox.dylib
/usr/lib/swift/libswiftGameplayKit.dylib
/usr/lib/swift/libswiftSpriteKit.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftMetalKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/usr/lib/swift/libswiftMapKit.dylib
/Applications/RhinoWIP.app/Contents/PlugIns/3DxRhino.rhp “3DxRhino.9” 9.0.26132.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 9.0.26132.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 9.0.26132.12306
/Applications/RhinoWIP.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 9.0.26132.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 9.0.26132.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 9.0.26132.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 9.0.26132.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 9.0.26132.12306
/Applications/RhinoWIP.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 9.0.26132.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Displacement.rhp “Displacement” 9.0.26132.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_STL.rhp “STL Export” 9.0.26132.1002
/Applications/RhinoWIP.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 9.0.26132.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 9.0.26132.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 9.0.26132.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 9.0.26132.12306
