Help with form making
I want to create something like this picture. Can anybody suggest how to achieve it? Any help would be appreciated
I created this and I want to connect it to the baseline above picture.
you will need several surfaces, maybe with MatchSrf too.
Thank you for your advice, i used MatchSrf the change was drastic so i guess it is not an option.
it depends on the input surfaces, I would suggest using some sweeps or networksrf , then rebuild, adjust some points and later Match
Thanks worked like a charm
