How can I make the tent smoother, like in the drawing? It’s much too pointy and distorted on the sides.I urgently need help. I’m very desperate. tent try 1.3dm (130.0 KB) Zelt yt tut.gh (9.3 KB)
Thank you! The problem is that it’s already too tense even without the bars. I want cleaner, easier curves, like the red line. I’m still a beginner, and I really don’t know anything about this.
Re Hello
I think you must follow what Daniel Piker said here,
you need different edge length depending on the location of edges.
You have 760 similar goals.
If you separate goals from naked edges and non naked edges you can have
For the render it is possible to subdivide mesh using a tool Like Catmull & Clark or SubD but it seems that there are no tools that accept fixed points ! (Except in my Nautilus plugin but it is not a free tool)
It’s a bit more work, but to get a nicer result for this sort of tensile structure it is better to build a mesh where the topology actually fits the shape.
Here’s how I’d approach the one shown in your image:
