Help on way to modelize some objects
Hello
Would like to modelise a net like on the picture. Is it possible do modelise it or to do that only in the texture ?
originally answered before, you need pufferfish plugin.download at
food4rhino.com
net_1.0.gh (10.2 KB)
thanks
could you send me you file rhino and grasshopper please ?
its already attached under the screenshot. net_1.0.gh
Hello, when i open the file i have nothing
could you please explain how it work ?
do have i to create a surface and apply the grasshopen on it ?
doest it create automaticly a net ?
thanks
well , you have the pufferfish installed?
if yes then with opening the .gh file in grasshopper you should see components and link between as the screenshot.
if no then install that and reopen everything and follow step above.
the net will be drawn at rhino perspective view automatically and the outer curve is internalized means it is inside the grasshopper component and you can replace it.
try and let me know if you are successful or not.
when i start to learn i did search youtube for “grasshoper for beginer” and there was quality tuts to learn from and i recommend you to do this and many time catching thinnnnng will be solved in less than 2 hours watchin.
