I’m a beginner. In the attached file, I have several surfaces. I would like to use the Net on Surface command in Grasshopper (using the pufferfish extension), in order to have a net that appears to be imploding. Im trying to make it look like a ball is hitting the net.
My issue, when I merge the surfaces lets say I merge the first dome, and square, and I apply the net to surface, it applies a net to both the square, and then the dome, which looks wrong, even though I select multiple surfaces. I think they need to be merged in rhino but this doesn’t work for me either nets.3dm (3.7 MB)
